CJT
Active Member
I have a new Lycoming 540 Thunderbolt engine with Dual SDS EFI in my RV10
Reading through the manual, I came across this statement Limit timing to 20 degrees for parallel valve engines. Adjust your RPM accordingly.
can someone throw light on the exact programming steps to achieve this?
also, after break in, what values to enter, to return to normal
