Engine Bolts
carl nank
Hi All,
I am installing my new replacement forward sump for the Superior Air modification. I need to replace some of the 1/4" X 1" bolts that bolt the sump to the engine.
I am ignorant regarding engine bolts. The thread goes all the way to the bolt head. Are these AN bolts? High strength AN bolts or what??? I believe the instructions call for 100" lbs of torque. (Will double check before torqueing).
Also can you get them from Aircraft Spruce? Or where would you purchase them.
I appreciate your help.
Carl,
The Lycoming part number is LW25-1.00. You can purchase them through Omaha Airplane Supply 800-228-9400. There may be a minimum quantity, not sure.
Allen
