TomVal
We purchased this aircraft in Dec 07. We immediately began working on complying with Van's fuel tank service bulletins. But then I got carried away and couldn't resist a few mods. As of yesterday, minus the logbook paperwork being completed, N1WS is once again ready to take to the skies.
Mod List:
Dual Flight Controls
Blast Tube and Shroud for fuel pump
Installed EDI - Engine Data Interface (FADEC)
Installed Infinity Stick Grip w/reversing relays (replaced Ray Allen Stick Grip)
Installed Aileron & Elevator Trim disconnect switches
Added a stainless steel re-enforcement plate to lower fuselage panel just aft of exhaust
Baggage compartment quick release tie-downs
Stowage clips for the aft cockpit control stick when not in use
Rear battery compartment access hatch
Modified battery compartment hold down brackets
Added Dual Battery charging cables
Oil quick drain
Complied with all outstanding Van?s service bulletins
Complied with TruTrak service bulletin
Complied with Lycoming AD?s
Upgraded fuel selector plate and knob
Added fire extinguisher
Silver Bullet Tailwheel Link
Modified AOA pressure/static lines
Added an AOA cb
Upgraded a lot of hardware
New Weight & Balance
Regards,
Mod List:
Oil quick drain
Added an AOA cb
![2009047v.jpg](/proxy.php?image=http%3A%2F%2Fimg14.imageshack.us%2Fimg14%2F930%2F2009047v.jpg&hash=09ace350c84d7819183280fcf3b93013)
![dsc00620y.jpg](/proxy.php?image=http%3A%2F%2Fimg13.imageshack.us%2Fimg13%2F1026%2Fdsc00620y.jpg&hash=77419ed7d5fe52d36af369f4d9ed7ef7)
Regards,
