I have just installed the ELT and wondered where those of you building a slider mounted the antenna.
uk_figs Well Known Member Friend Mar 9, 2007 #1 I have just installed the ELT and wondered where those of you building a slider mounted the antenna.
TX7A Well Known Member Mar 9, 2007 #2 Look below click this link http://www.vansairforce.com/community/showthread.php?t=14611 (...a few threads below your post on the RV7 main page just a bit and you'll see the two-page thread on the very subject...with pics.)
uk_figs Well Known Member Friend Mar 10, 2007 #3 ELT antenna Thanks, good thread. As I have used the vans sidewall mount I think I will mount the antenna outside between the slider and tail as discussed, will be an easy cable run and install as I will just have to make a backing plate.
