Gagarin737
I received my ACK E-04 ELT and revision 42F.
When you install the ELT according plans it will not fit. The aft side will interfere with the edge and fuel tank. You have to install the ELT more forward (9/16"). The forward edge of the bracket will be almost flush with the structure.
Besides that when you install the brackets according plan you'll not be able to open/close the straps. The forward buckle interferes with the structure.
After install there is a procedure to check the GPS input but it failed. I checked all wires to the ELT (GND/12V/GPS data in/GPS out).
Do I have to alter the setup for the serial output from the Dynon or must it work out of the box?
![img2493q.jpg](/proxy.php?image=http%3A%2F%2Fimg403.imageshack.us%2Fimg403%2F8889%2Fimg2493q.jpg&hash=737c0a4a59c74d14ffe5c1e8a6010469)
![img2488td.jpg](/proxy.php?image=http%3A%2F%2Fimg855.imageshack.us%2Fimg855%2F5732%2Fimg2488td.jpg&hash=22a63530c881753b7b932403332c1113)
