jeffw@sc47
Mounted the elevators to the horizontal stabilizer this afternoon preparing to mount the fiberglass elevator and stab tips (Emp pages 11-02 and 12-06).
When the elevator counterbalance arms are lined up with the horz stab the trailing edges of the elevators are out of alignment by 3/8" (rechecked after firming things up and using a laser level) with each other; the right elevator is down. Everything that needs to be in alignment on the HS and each elevator independently are 'perfect'; the leading edges of the whole HS in alignment, the top and bottom skin surfaces of the HS front and rear spars each side in alignment. The elevator horns are out of alignment by 1/4"+/-.
![](/proxy.php?image=http%3A%2F%2Fi1382.photobucket.com%2Falbums%2Fah253%2Fheffnhane%2F6e2d205d-8b79-405c-8981-09d6eb6fb4ad_zpspid4teyl.jpg&hash=0b3163f6cc07ee458cea52167dad3352)
This misalignment made me think that I may have done something wrong along the way but I can't find anything I may have messed up. I would have expected near perfect alignment of the trailing edges or at most 3/32" misalignment but I can see this from across the hangar.
I can't imagine there is any adjustment for this and that the driver for alignment is to make the elevator counterbalance arms true to each HS side and live with the up/down elevator trailing edge misalignment and the elevator horns will be off but not as apparent unless you look close. I assume that this is more a cosmetic issue more than an aerodynamic one (or is it potentially an aerodynamic problem?). I don't like it much.
My question for the rest of the 14er's is whether they experienced the same problem, and is 5/16" misalignment too far from a reasonably acceptable tolerance for alignment to expect from the new 14's integrated CAD/CAM manufacturing? Just order the wing kit and I hope there aren't similar issues with any alignment problems with those, anything there would likely be an aerodynamic problem.
