Atacamandy
Member
I have been reading the online post here and I believe I know the answer, but I am not sure how to proceed. Here's the problem:
The left elevator is a 1/4" higher at the root and 1.8 degrees higher at the root than the right elevator. This leads me to believe that one of the elevators are warped or both are warped. The out board measurements are exactly the same with the exact same angles.
So my 1st question are is a 1/4" higher on the left at the root significant?
Is the 1.8 degrees at the root significant?
Lastly, if the answer is yes to the questions above how do I determine which one to fix or both, and how do I fix the warping? One suggestion was to drill out the rivets and start over.
Thanks for looking and offering your opinion.
