Future RV 9 Flyer
Active Member
Working on elevators and had a question about electric trim. is it worth the extra cost? Ditto the aileron trim.
is it worth the extra cost? .
Wrong question I think. Compared to the total cost of a build, it's a fraction of 1%. So instead, think which method you want to fly with. As you can see you'll get die-hard adherents to either method.is it worth the extra cost?
For the weight conscious aircraft builder seeking accurate data, this perennial topic is a very good place to make a direct comparison devoid of personal bias. Die-hard fans of the manual system may be unquestioningly fond of their preferred choice of trim system but such ardor cannot lessen manual trim's one truly significant drawback....weight. The heavy steel cable assembly that is the very heart of the manual trim system tips the scales at a hefty 2.5 pounds. That substantial amount of weight does not include the required turning knob, mounting bracket and associated installation hardware. Are the sum of those parts effectively reducing leg wiggle room some builders report?.....Electric pitch eliminates the big knob and cable loop that eat up leg wiggle room.....
I like being able to turn the knob in very tiny increments to get the manual trim just right. Having said this I have never flown with electric but visualize it being like my car window, where I can not finely adjust it. I am sure you can slow electric down but do you have a two position switch in order to have fine and course trim?
By way of direct comparison, the total installed weight of an electric trim system is approximately 7-8 ounces. Do the math and then decide if you comfortable with a manual trim system that is at least 5X heavier than electric. ...
VAF members have reported that Van's chooses to install electric trim in its own factory built airplanes. Why is this so? If actions speak louder than words, Van's clear preference for electric does not exactly shout a ringing endorsement for the virtues of its manual trim system. ...
I'm still on the fence with the electric vs. manual flaps because with manual, you can put them WHERE you want them WHEN you want them. I'll probably go with electric in the end as that appears to be the only option for the 7 without rolling my own system..
WARNING. THREAD DRIFT ALERT!......I'm still on the fence with the electric vs. manual flaps because with manual, you can put them WHERE you want them WHEN you want them.....
Electric trim can run away. Manual trim will not.
Most modern airplanes have electric trim because is is convenient and cheaper to install. Most modern airplanes have run away protection of some sort. Be aware, with the RV's there is no run away protection except hit the switch in the opposite direction.
