There has been a lot of prior discussion on this.
Try doing a search or two, here in the -10 forum-----go back to the start of the forum, dont limit the time frame.
Basically in nut shell, the original design had one tab coupled to the flaps----(this is from Mel), and that didnt work out as planned, so they just hooked both flaps up to the same bell crank, without doing a total re design.
This resulted in the tabs going through a lot of monkey motion in the travel, looks really strange.
But, in practice everything works just fine, seems to be a total violation of the TLAR design rule, but is in fact a non problem.
Just follow the plans, shake your head at the monkey motion part, and live with it.
