You would think that hooking up a manual trim tab cable would be a no brainer but I have been dealing with this for several weeks and I am getting frustrated.
I built the elevator and trim tab from prepunched parts out of the original kit I bought from another builder. It fits well and the elevator is straight. I mounted the trim tab horn using the prepunched holes, thinking this would be a piece of cake.
No way the manual elevator trim cable would fit. I had 0 degrees down travel and over 90 degrees up travel. The clevis and pin were the wrong sizes. I called Van's twice and they said the cable was the same from the beginning of time and it should fit.
I figured out that my kit used a steel clevis and in those days builders had to make a different kind of trim tab horn that was riveted to the side of the trim tab. Then Vans went to a nylon clevis. I tried to buy a nylon clevis from Van's but they referred me to their supplier. I finally got the nylon clevis from Ray Allen and it is much shorter.
Using this clevis however didn't make much difference so I ended up cutting back the trim tab horn about a half inch. I also cut off some more of the bottom skin on the trim tab. I can now get almost 35 degrees of down travel but the trim tab bottoms solidly against the elevator.
In order to get the cable to work however, I am going to have to move the WD415 back a half inch or more on the elevator cover plate. (The cable is already moved to the end of the allowable travel on the WD415 nut). This will also entail cutting a much longer slot in the cover plate.
There must be something different about this older manual cable. Anyone encounter this kind of difficulty on an older 6 or see any problem with modifying the cover plate?
Dave A.
6A build
![start.jpg](/proxy.php?image=http%3A%2F%2Fpages.suddenlink.net%2Ftismuoi9%2Ftrim%2Fstart.jpg&hash=59b27fc3bcfc0bf977d8a50521c8d29e)
![clevis.jpg](/proxy.php?image=http%3A%2F%2Fpages.suddenlink.net%2Ftismuoi9%2Ftrim%2Fclevis.jpg&hash=9c47287a00c180a4c2affe1b104ab4f1)
![hornshorten.jpg](/proxy.php?image=http%3A%2F%2Fpages.suddenlink.net%2Ftismuoi9%2Ftrim%2Fhornshorten.jpg&hash=9d642b0ee8a67bba21a79002ccb3c665)
![plate.jpg](/proxy.php?image=http%3A%2F%2Fpages.suddenlink.net%2Ftismuoi9%2Ftrim%2Fplate.jpg&hash=1ca45a9d27395acde350d2ed20240e9f)
Dave A.
6A build
