CDBridgesRV7A
Active Member
Good Day All,
I seem to have run into a wee problem. I just re-made the trim tab hinge for the 3rd time so now the elevator trim tab is ready to be riveted. The plans say to start with the bottom side, however how do you set those 426 3-3.5 rivets that attach to the trim tab spar? Once everything is clecoed together I can't get to the shop heads to set those rivets. Do you use flush pop rivets?
Thanks for the help.
Cheers
Chris
Cheers
Chris
