docrichardson
Member
Good Morning,
I'm building the elevator trim tab and ran into problems following the construction manual when it came to riveting the E-917/918 trim tab horns to the E-919 skin. Do you bend the ends of the trim tab first, or rivet the trim tab horn before you bend the ends? Based on a couple of builder logs I checked before I started, they said to bend the ends first and then rivet. When I did this the aft most 426 rivets ended up at an angle...and I ended up putting extra dents in the trim tab...don't want any repeats of that with the new one arriving today. Please share what worked for you guys. Thanks!
Mark
Mark
