bpattonsoa
I have looked thru the archives and can't find any posts relating to the sensitivity of the elevator trim at cruise. I have not been able to trim the ship level because just a touch of the trim gives me 2 - 3 knots change. Checked on the ground and the system operates correctly.
Same issue as my -6 A, solved easily by a Ray Allen speed controller, but with the -10 slow trim would not be a good thing in the pattern. These things require a lot of trim to land where on the -6A you just pull throttle and land.
I plan to put a micro switch on the flap tube to cut a speed controller into the elevator trim power when the flaps are at full up. Will also act as a reminder if I forget to go full up in cruise.
Any comments?
2.5 hours into phase 1 and watching it rain, bummer!
Any comments?
