Built the trim tab and mounted it on the elevator. Installed the electric trim servo kit from Vans. Hooked a battery to the servo and stroked the servo to look for interferance between the linkage and the structure. (Three sentances doesn't look like ten hours of work does it)
At full up trim the linkage just touches the skin of the elevator and the tab skin impacts the rear spar of the elevator. I will probably adjust the length of the linkage to prevent this but it's currently set to stroke equally in both directions.
My questions are:
1. If I adjust the linkage toward up trim can the position indicator be "zeroed" to other than mid stroke of the servo?
2. Does the airplane really need that much trim capability? Seems to me that if one needed to deflect the tab to this limit during flight there would already be a whole lot of other issues the operator would be dealing with but I have no experience with this.
The plans said to trim off part of the control horn on the tab for use with electric trim. I would put a slightly taller horn on if it didn't mean throwing the tab away and starting over.
My questions are:
