I followed the plans and watched the video and I still am unhappy with the way my trim tab turned out. I am right on the bend lines but there seems there is not enough skin material on the sides causing these areas to be slightly concave as compared to the rest of the surface. Is that a normal result or an anomalie? All the holes line up perfectly.
In other words.....How much perfection can I expect to achieve? Have any of you all built a perfectly flat Trim?
Thanks!
Thanks!
