jhearnsberger
Active Member
I have the elevator trim bellcrank installed and I have the cables routed back to the elevators. I was able to thread the E-616PP Cover Plate onto the CT Q-43 cable that is running back to the left elevator. However, there is not enough slack to thread the coverplate onto the cable running through the right elevator.
Common sense tells me to just loosen the cable at the bellcrank. But, it does not mention anything about having to do this in the plans. I want to be sure I am not making a mistake somewhere. I'm pretty sure both of the cables were the same length.
Jake
Jake
