precession
Hi all. Since I'm not the original builder of my 4, I'm hoping this question isn't too ignorant.
This is a picture looking through the inspection hole at my elevator control horn. Hopefully (assuming I uploaded the photo properly) you can see to the right two black marks on the lower face of the rear spar of the vertical stabilizer. Those marks are from the elevator horn contacting the spar when the control stick is pulled to the full aft position. It's the contact of the horn on the face of the rear spar that limits aft elevator travel. I'm just wondering if this is correct. Seems to me it isn't that healthy to have the control horn impacting the face of the rear VS spar (but what do I know?).
That said, as you might guess, I've never moved the elevator during flight far enough to make contact. It only happens during pre-flight and pre-take off when checking for free and clear elevator travel. But I'm still wondering if this is correct or if something else is supposed to limit elevator travel.
Thanks in advance for any input.
Bill
Bill
![v41ie1.jpg](/proxy.php?image=http%3A%2F%2Fi43.tinypic.com%2Fv41ie1.jpg&hash=cdab242e61a3020ded6defd07a9ce206)
