TedsNumberOneSon
Active Member
Chapter 9 page 09-08 The instructions shows to taper the end of the respective E-01423 trailing edge. It appears that the reason for this taper is so that the end of the trailing edge will nest inside of the trailing edge of the E-912 elevator tip where is slips inside of the skins. I think I got the right elevator fitted pretty good actually slipping the E912 tip in the end to check the fit. The left side is another question. As seen in the picture there is nearly .6 inch on my E-912 where where is no opening to fit the trailing edge into. It doesn't even appear that the tip is open at the longitudinal location where the hole is meaning I would have to taper the hole off to make it slip inside. I did some search on the forum but did not find this specifically and I am open to suggestions.
I tried to make it load the photo but instead I got this photo bucket link. First time.
![20150301_143021_zpsn4yqn3rr.jpg.html](/proxy.php?image=http%3A%2F%2Fs374.photobucket.com%2Fuser%2FTerrell_Yon%2Fmedia%2F20150301_143021_zpsn4yqn3rr.jpg.html%23%2Fuser%2FTerrell_Yon%2Fmedia%2F20150301_143021_zpsn4yqn3rr.jpg.html%3F%26_suid%3D142524156522807053323639564208&hash=33c43b70ca10a11592915c2024040040)
