Sorry, another question and I couldn't find the answer by searching. When exactly should I apply the epoxy/sealant to the rear of the stiffeners?
1. Just as I'm bending the trailing edge?
2. After I bend the trailing edge and before match drilling the skin?
3. After I bend the trailing edge and after match drilling the skin to the spar/ribs?
Little confused as to when's the best time to do this.
Also, there are 8 holes in the left skin for riveting the skin to the trim spar, these are the ones outboard of the trim tab. It looks like I'd be better off match drilling and dimpling these BEFORE bending the trailing edge, at least I'd be able to use by DRDT2 to dimple. Any thoughts?
