When dimpling the trailing edge stiffener hole, despite being careful to position the elevator as level as possible in the C-Frame, there was a little distortion around the holes, mostly evident on only one hole. I opted not to use the pop rivet dimple die because it tends to enlarge the holes.
Any ideas as to how I can correct this distortion? Should I attempt to hit it again in the die? Also, this is a troubled location for cracking. Should I be concerned with this? It may flatten out when I rivet the stiffener.
Thanks!
Thanks!
![showmy.php](/proxy.php?image=http%3A%2F%2Fhttps%3A%2F%2Feaabuilderslog.org%2Fshowmy.php%3Fp%3D7YL1dRvO9%26z3%3D%26i%3D3087417%26l%3D39154%26t%3Dm%26f%3DIMG_0313.jpg&hash=6e52988ce58300e0849398bae37e13a5)
![showmy.php](/proxy.php?image=http%3A%2F%2Fhttps%3A%2F%2Feaabuilderslog.org%2Fshowmy.php%3Fp%3D7YL1dRvO9%26z3%3D%26i%3D3126571%26l%3D41628%26t%3Dm%26f%3DIMG_0314.jpg&hash=15e3bebfdc0221f3ca0406316decfbbe)
![showmy.php](/proxy.php?image=http%3A%2F%2Fhttps%3A%2F%2Feaabuilderslog.org%2Fshowmy.php%3Fp%3D7YL1dRvO9%26z3%3D%26i%3D3200403%26l%3D44369%26t%3Dm%26f%3DIMG_0316.jpg&hash=0766ca1358e150d8e0701362713fd9f2)
