TravisHamblen
Active Member
This afternoon I made a very disturbing discovery during a pre-flight inspection of my RV-7A. I noticed a skin-crack around a rivet on the top of the right elevator. The crack goes around (making a ?V? shape) the forward most rivet that holds the stiffener on under the skin. The crack was about ? and inch in length on each side of the rivet. I took some photos to record the crack and my (temporary) solution.
To correct the problem (until I can reskin the right elevator), I stop drilled the crack at both ends, and deburred the drilled holes. I then taped off the area I wanted to patch and made an exterior skin patch using JB Weld. I made sure the JB Weld went into the crack and also made about a 1.25? square patch covering the surface of the entire effected area. I was careful to stop the patch close to the drilled holes so that I could closely monitor for continued cracking. Once it all cures for a couple days I plan to fly the plane to see if the patch holds or if the cracking continues beyond the stop drill holes.
I know of a couple people that this has happened to, but never to me! I know it is not uncommon, but it sure is upsetting to find! I wanted to get a consensus on what others have done in the past and if they were successful. I do plan to reskin the elevator just so it is perfect, but hope that the patch and stop drilling will work to keep the plane in service until I get done with the new skin. I would love to hear anybody/everybody's opinion on this and let me know if my temporary patch is/was a good idea.
Take a look at the below linked pictures (view them from the bottom up).
http://www.flickr.com/photos/26323343@N05/?donelayout=1
