RV7Factory
Chief Obfuscation Officer
It's official... I am frustrated!
I have been trying to rivet the first elevator skeleton for two days now and things just seem to be going from bad to worse. For the life of me, I can't figure out how to rivet the tip rib assembly (E-703 & E-704) to the elevator spar (E-702). The rivets that go through the spar web and the aft flange of the counterbalance rib are proving to be a big PITA! As it stands, I have bent over four rivets (two each hole) and now after drilling them out the holes have become enlarged. I just can't seem to be able to get the rivet gun and/or bucking bar in there.
I don't like the looks of what's left, but before I run over the parts with my car and order new ones, I figured it was worth one last attempt (just kidding about the car).
I am thinking of fabricating little doubler plates to somewhat address the enlarged holes (not sure if that is a good idea), or I thought of enlarging the holes further and using two large BSPQ-5-4 pop rivets. Any thoughts, comments or suggestions?
Thanks!
Thanks!
