I am a new owner of recently purchased RV7A. We are conducting an import inspection for registration in Canada. In doing the inspection we have found that the centre push rod for the elevator control was not properly secured allowing it to rotate and unscrew from the rod end. In further inspection we found that the stick hits the panel and I cannot determine where the control stops are located. The elevator deflection is not correct (23 degrees down and 27 degrees up). Can anyone provide copies of the rigging instructions for the airplane? I have the drawings but they don't have the information on the process for rigging that I am looking for.
