AboveMSL
With the mirror like reflection of aluminum and, getting used to needing reading glasses to see any darn thing I'm doing up close, I managed to botch one of the rear pulled rivets on the right elevator 2nd inboard rib. It needed to be drilled out, and I knew going in, because of the tight quarters and given difficulty of removing pulled rivets, that I'd likely dork it up. Well, I didn't disappoint, I dork'ed it up quite nicely. So I have two questions please. 1) What should I do about the existing hole? Debur the edges (with a scotchbrite pad) or upsize the hole? 2) If there is enough edge distance can I just drill a new hole, or will I need some sort of doubler now? As always, thanks for any advice.
[/IMG]
![30109c2.jpg](/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi62.tinypic.com%2F30109c2.jpg&hash=c4624ce927cf303e18b08fb2d10e2957)
