JanRV6UK
Elevator pushrod F689 looks to be a tight fit to get in place
? Is the general way to get the that one in place to feed it in from the back ? Removing both Heim Bearing to make it as short as possible ? and then ?bend? it ... to get it in place ? No way that I can feed it straight in ? Unless I am missing something obvious ! (I do not like the idea of bending a tube that works in compression ....)
One idea I have is to put a feed hole in bulkhead F607 ? almost at the centreline joint ? Then I think it will just fit in ? with a slight push to one side ... I have not cut the tube to final size. My experience with cutting to final size as per drawing does not always work out very well ! I like to work from oversize ... trimming to fit ...![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
What have others done ??
