Elevator mount gap
MekMouse
Active Member
After making sure I didn't have to replace my H-stab rear spar :) I figured I'd get to mounting tge elevators and the rest of section 11.
That's when I ran into a small conundrum. Instructions say to make sure to fill the gaps with 960-10 washers. As the pics show, clearly there is no gap. In fact these are significantly closer than a gap.
So the question, is thus a normal starting gap with the pre punched holes and its totaly normal to bend the brackets away from each other?
The side question is do I actually have the correct swivel link for the ms3614r?
Yes just spread the hinge brackets.
The 960-10 washers go on the outside of the steel hinge brackets.
The note about filling the gap is about the gap between the center bearing and each elevator horn - not the rod end bearings.
I made some wood wedges that I could push in to spread them. This makes putting elevators and rudder much easier. instead of trying to keep all of them aligned while spreading the others in turn.
Thank you gents for helping me make sure I wasn't overthinking a simple situation.
And thanks for the wood wedge tip for the install :D
