pilot28906
I just realized that when riveting the leading edge skins on the right elevator that I got the bottom skin over the top skin. Will this be a big problem with water leaking in?
Actually you got it right. Or at least mine is the same way. Since there is a 90 degree bend on the part that goes on the inside of the overlapping skins you can't get it wrong. It is just designed so that the tooling that puts the 90 degree flange in the elevator skin does both skins the same.I just realized that when riveting the leading edge skins on the right elevator that I got the bottom skin over the top skin. Will this be a big problem with water leaking in?
John, yes it is a potential for water damage according to plan and drawing. Good news is the pulled rivets are really easy to drill out, flip the top skin over the bottom skin and re-rivet. Won't take 15 minutes. You can see mine at www.mykitlog.com/sglynn
Mine had 90? flanges on the leading edge of one side of both elevator skins. There is no way to do it any other way. One ended up on top, one on the bottom.
Maybe they made a change somewhere down the line and stopped putting that bend on the elevator skins?????
Yeah, sounds like Van's made a design change then. But Brian, your builder number is higher than mine, so maybe the change was to add the flange, not remove it. My DWG 5 was at revision level R2, and did not have the 90 deg flanges. Brian, what revision level is your DWG 5? The revisions are listed in ascending order above the title block on the bottom right corner of the drawing. Now I'm curious. I wonder what motivated the change, and what else might have changed?
He He,
Even though I have a newer builder #, my tail kit started life as an RV6 and was converted by using the conversion kit that was made available when the RV7 was announced. They gave me a new builder # when I ordered my wings.
I have been building for over 10 years (long break between tail and wings).
My elevator skins are some of the first RV7 skins I suppose.
