Dimple or no dimple?
...(as you have surmised), that depends on the rivet callouts, so stick with proper hole prep based on the rivet called for.
Early on, the instructions will call out dimpling or no dimpling, but as you move through the plans, this will happen less and less often. You will be required to understand what you need to do and when you need to do it (i.e. breaking the skin edges), based on the hardware called for. Enjoy!
