RV7Factory
Chief Obfuscation Officer
Tonight I was *trying* to work on my elevators but apparently the aluminum gods aren't happy with me. I am having problems getting the holes to line up where the E-702 Spar, E-702 Tip Rib and E-704 Counterbalance Rib all come together. I realize these kits aren't manufactured to space shuttle tolerances, and a bit of rework is normal, but this is off a more than I have seen prior. I have tried tweaking the flanges somewhat, but if I make one set of holes line up, others get worse. Anybody else have fit issues here? If so, what did you do?
If I get the little tabs to attach to the spar flange, I end up with this nasty space between the counterblance rib and the tip rib. But wait... it gets worse...
Yikes, those aren't even close. If I cleco these, then the holes where the tip rib attaches don't line up (at all).
I don't know if this is related to the problem above, but I might to email Van's about this... the flanges of the tip rib are bent at different lengths. The holes are about 1D difference in distance from the web. It's fuzzy but you can see the difference in flange lengths at top center.
![050815_002.jpg](/proxy.php?image=http%3A%2F%2Fwww.rv7factory.com%2Fimages%2Flog%2F050815_002.jpg&hash=3f8c6a0c97a755e282e2d5762461fc35)
![050815_003.jpg](/proxy.php?image=http%3A%2F%2Fwww.rv7factory.com%2Fimages%2Flog%2F050815_003.jpg&hash=18b98bf5b45063e173caa87b7b6f1c8e)
![050815_004.jpg](/proxy.php?image=http%3A%2F%2Fwww.rv7factory.com%2Fimages%2Flog%2F050815_004.jpg&hash=eab0023f3c050d5116b7a449491d34cc)
