I'm working on the right elevator and am hoping one of you can help me out.
Van's instructions state to align the tube portion of the elevator horn with the centerline of the elevator spar. If I cleco the horn to the spars using the existing holes, the centerline of the tube angles slightly and is about 3/64" offset from the centerline of the spar.
If I try to align the centerline of both pieces, I'll end up with figure-eight holes in the spar. Is it more important to just get the tube and spar aligned, even if they are off-center a bit, or should the centerlines of both pieces also align?
Any suggestions?
Mike Behnke
RV-9A Empennage
Andover, MN
![10017736ku.jpg](/proxy.php?image=http%3A%2F%2Fimg224.imageshack.us%2Fimg224%2F4208%2F10017736ku.jpg&hash=27d94dab2fdc65ffcb2414d5542bdcf5)
Any suggestions?
Mike Behnke
RV-9A Empennage
Andover, MN
