TX7A
I have drilled-in my HS to the fuse and was doing a preliminary check with the elevators on the HS. The flange of the right elevator horn slightly rubs the edge of the rectangular opening of the F-714 aft deck. At first, I thought that I had not centered the HS to the fuse. But, after measuring from multiple points, the HS is centered and perpendicular to the fuse centerline as close as I could ever expect. (+/- 1/32?) It is possible the weldment may be slightly off, but it is negligible. The left side has about 1/8? clearance. I seems that I could shave-off a little of the opening of the aft deck to get clearance.
Has anyone had this problem? Suggestions?
![rtelevatorhornrubsdeck20jq.jpg](/proxy.php?image=http%3A%2F%2Fimg207.imageshack.us%2Fimg207%2F6671%2Frtelevatorhornrubsdeck20jq.jpg&hash=3c83b35ccc60ddb1a2798362e2a6c231)
