Pat Stewart
Problem:
Drilled my elevator horns after setting bearings to the .875 dim on the print however did not rig to horizontal. Once rigged to horizontal, leading edge of elevators are too close to the aft spar of the horizontal.
Solution:
Installed .100 shim under center hinge. This solution leaves the elevators in the correct location relative to the horizontal however it does move the rotation point .100 aft. It also requires adjusting the rod end bearings .100 in the torque tube.
Seems simple and worked well.
New Problem: After calling and discussing with Vans they suggest welding up the holes in the elevator horns and re-drilling vs. the shim option.
Has anyone else done something similar.
GreyHawk10
Solution:
GreyHawk10
