Berchmans
I am at the point were I am fitting up the elevators. I have them installed and distances correct so that the elevator horns line up nicely. However I note that the the elevator horns that I have are not pre-drilled for the installation of the AN 4 bolt that joins the two elevators through the main support bearing in the center. This is not the point were the control rod will attach but the bearing above were the elevators are joined. I have looked through the plans and instructions but can find no information or references to drilling those holes. Any suggestions from the membership would be most appreciated..........
