wjb
Hi Folks,
This will warrant a call to the mother ship, but I wanted to see if anyone else had some experience with this.
I'm nearly done with the empennage (I did riblets, thank you very much!) and am fitting the elevators to the HS. The fit up went well and everything is in good alignment and ooh so smooth, however, I found that the elevator horns are not stacking up to the same height. See photo:
One horn is about 0.2" lower than the other. Anyone else see this on their bird? is this a tolerance issues on the horns, or something else? I'm not sure it would actually make much difference one everything drilled and bolted together, but it took me a bit by surprise.
Thanks much,
-Bill
Thanks much,
-Bill
