Wondering about the difference in bolt length on the dwgs for upper and lower bolts on the elevator control horn:
DWG 27A shows AN3-10A (with one washer under the nut) to connect elevator pushrod to horn while DWG 5 shows AN3-14A at the top. That one goes in with 3 or 4 washers on each side of the bearing per the drawing.
I guess use a 14A with washers just like at the top?
Oops! Was looking at the preview plans rather than full size dwgs! Sorry.![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
