We finished rigging the elevators and the manual says there will be some offset with the horns, ours are off about 1/4 inch.
Everything seemed to rig well and we get the minimum 25 degrees of negative deflection and at least 30 positive, but the left elevator has considerably more negative deflection (almost 5 degrees) than the right, guessing due to where I drilled the hole.
Any thoughts? Just leave and "build on"?
Assuming that the final rigging will not be full deflection .. haven't read that far ahead.
If I did want to get them more consistent I guess I would need to have someone weld the hole and re-drill, not sure how that's going to look.
