SuperCubDriver
I messed up the drilling of the Elvator Horn WD-605-R1. Although I got acceptable elevator deflection, the elevator did start to chafe on the upper inside at about 25* up deflection. Now I had a closer look and I found that the drilled hole is not in the correct location. So when I pull the hinge bolt out of the center bearing all is o.k. It is embarrassing but I did drill the hole in the wrong location somehow. I attach a picture on which I marked where the hole should approximately be.
So I am looking for a solution to get this straight. I am thinking of enlarging the hole and insert a selfmade bushing. I e-mailed Vans, still waiting for answer.
Any input is welcome.
