Vans says trim the horizontal stab to prevent the elevator from rubbing. The control arm only allows so much movement of the elevator in one directIon but there is no mechanical ?stop? going the opposite direction.
Is there a number of degrees of throw that I should be looking for? How much hstab skin did you trim? How did you know when it was enough?
