Elevator Error????
sapeloson
Just realized I dimpled the top flange of the E606-PP. Book says to "machine countersink", I'm sure thats so the trim tab hinge will set flat. What options do I have or, do I need to replace the part and start again?
Thanks for the help!
Ordering standard wing kit next week........
Tim
http://www.mykitlog.com/sapeloson
Replace it
Replace it--pretty cheap part. Here is a link to Andrew's RV7 site. He had the same issue and replaced with a hinge that was a bit wider--allowed for better edge distance. (Hope he doesn't mind that I shared a link to his log). Andrew has a great web site. Build on!
Skyking 902001
RV8
Emp done
QB Wings & Fuse on order
Save your money
Save your money for a more critical screw-up. Flatten it out with two flush sets, then counter sink it and build on. Do a search, and you'll get more of the same advice... You're not the first to do this (I know of at least one other ;))
I did the exact mistake
Tim,
I did the exact mistake, I replaced the part because it's cheap, and there are plenty to do while I wait for the part.
But, like flyboat said, there are worst "Oops" ahead, it's your call in the end.
Hank
Thanks for the quick replies fella's! I'll make a desicion today........just faxed in my wing order!
