claycookiemonster
Checking elevator travel today. Up travel is nicely within the tolerances of plus 25-30 degrees at plus 27 degrees, and both elevator horns are in contact with the stops at that point. The challenge is the down travel.
One elevator horn contacts the stop at 22 degrees down (range is 20 to 25) however the other horn is about 1/16" from contacting the stop at that point. My concern is if we file the stop away to allow the horn that is NOT contacting, we may exceed the 25 degree limit.
The F811D-1 elevator down stop has already been riveted in place. Another option would be to drill it out and replace it with another stop which will contact both horns but not exceed the travel limit.
