Adam Oke
After a hiatus on the tail due to work, I have returned with a relatively simple question.
I am about to drill my counterweights using E-713 as a guide. I plan on using a #40, then stepping up to a #12. I also plan on using some cutting lubricant. I just want to ensure that I will be relatively square when drilling. How did everyone ensure everything is square to meet edge distance on H-703 flange? Ideally, I would like to clamp the entire unite and use a drill press, but there doesn't seem to be a good way to do it.
Did everyone just freehand it horizontally on the table and hope for the best when it came to edge distance on the H-703 flange?
