(Pics shown below)
So I'll start by saying that this tail kit came from a previous builder that left me with the elevator final assembly point to pick up at.
The previous builder had slightly elongated several holes in the counterbalance rib that I was able to clean up round for .128" oops rivets. This should have probably threw a red flag and told me that the parts were not fully correctly formed/fluted when he final drilled them. But instead (hardly knowing any better) I pressed on and when I finished this right elevator, I did notice a little warp in the counterbalance arm and figured I would wait and see how it looked in the tailcone attach phase. Now I have it attached to the horizontal stab, and the upper surface just nicks the horizontal. The lower surface looks fine.
So the way I see it:
I'll either blend out the forward part of the counterbalance skin and rib, and still have more than 2D e/d to the rivets.
Or I can later on in the build, when I have some down time, build a new counterbalance assembly, and have to use a few more blind rivets this time.
By the way, I'm at the point where I am ready to drill my center bearing hole through the elevator control horn. I don't see any reason to let this counterbalance issue keep me from proceeding to drill it out, right?
Current condition:
https://lh6.googleusercontent.com/-...I/AAAAAAAAAWY/xGsMiCDq85w/w485-h861-no/13+-+3
Sharpie somewhat showing if I was to feather the counterbalance skin:
https://lh3.googleusercontent.com/-...I/AAAAAAAAAWI/sy8IaKi_nZ8/w485-h861-no/13+-+1
Current condition:
