Just curious if any of you added more counterweight to the elevator than Van's supplied. I know I could add a bit more to get it to balance perfectly. On my RV9, I had to drill some of the lead out to make it perfect but on the RV10 there just was not enough weight. What have you guys noticed? I am thinking of adding a bit more to get it balanced perfect before paint paint (Paint may change it again) but I am not sure if it is worth the trouble. Balanced controlled surfaces are important for flutter. Just not sure how far to go with this on the RV10.
