Bill.Peyton
Since my fuse and wing kit are a month late I decided to use the down time to do a little pre-paint work on the empenage. I ran 2 inch glass cloth 6 oz. strip around the elevator tips and all the rest of the fiberglass fairing attachment points to stabilize the joint, and using body filler, faired them into there respective control surfaces. I would like to check the balance of the control surfaces to verify them prior to paint, which will occur way in the future.
I do not have the final inspection and flight test document yet, but do understand that the elevator is 37.5 inch lbs and the rudder 30.8 inch lbs.
Does Vans provide a procedure to check the balance after finish and paint? Has anyone checked this after body work and paint and had to add or remove weight?
Bill
Bill
