I was wondering how people have wired the elev trim motor in the stab. Where do you route the wires, thru the hole for the screw or make another. Have you made it one continuous wire, ie spliced, or have builders put a connector on the aft deck.
I used a dedicated wire hole, and used a 5 or 6 pin connector that was on hand, left over from who knows what. wanted the ability to pull the elevator off without having to monkey with the wires.
