greg gfeller
Member
Hello, How many of you have experienced a failure of the red fuel cube? Yesterday my GPH was reading zero. Also my fuel electronic fuel gage showed I was burning more fuel than actual and to top it all off my oil pressure which usually runs about 58-60 psi was fluctuating to 66 psi and fuel pressure fluctuating between 2.8 and 5.4 psi in level flight. I have gone through and checked grounds and connections and all seem fine. The plane had not been flown in over a month and the Dynon backup battery was at a very low charge where when starting the aircraft it froze up with a white screen with a line vertically through it and I had to do a hard reboot pressing buttons 1,2 and 5. So still not sure if it's the fuel cube that failed or something else with all the odd readings. Any thoughts? Thank You![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
