electric trim
pokey
Active Member
After 20 years, today the electric trim would trim nose down but not nose up. I will trouble shoot for loose grounds tomorrow any other ideas? Thanks
Bill
Bill
Very common if you have an older RC Allen trim relay. The contacts go bad, and the first symptom I always got was that it would work in one direction only. You might check the relay - they have a newer version.
Paul
Ditto everything Paul said.
The old RC Allen relays are notorious for crapping out after about 400 hours. That's the problem 95% of the time.
