rapid_ascent
I've been working on my HS and I have just put together the front spar. On DWG 7 there is a note to drill a 5/8" hole for the trim cable in the front spar and a 7/16" hole for the trim cable in the rear spar, but I have electric trim. The instructions or the drawing doesn't mention what to do if you are using electric trim. I'm assumming that some wires have to be routed through similar positions.
If anyone could enlighten me that would be helpful. Any pictures on how you routed the wires would be really helpful.
