Use a 9-volt battery or a cordless drill battery to run servo back and forth to its center position. Install the servo in the elevator and use tape to hold the trim tab in the neutral (center) position on the elevator, just line up the trailing edges. You can then mark and cut the threaded rod to the desired length to fit the horn on the trim tab.
