Space Cadet
Was just running some fuel through the system on the ground for the first time using the electric pump, out to a gallon jug from the fuel servo output. Was surprised at the low fuel flow coming out, didn't seem like enough to run the engine at full power. Was not a strong flow like I would think. Engine started and ran fine, pressures okay. Throttle and mixture full open. Is this correct or do I have a restriction somewhere to go hunt down?
Dwight
Dwight
